Forums >> Revit Building >> Technical Support >> column Doric, the shaft extends beyond top capitel
Tue, Nov 27, 2007 at 9:47:39 AM | column Doric, the shaft extends beyond top capitel
avaline
The shaft of the doric column extends above the top capital sme 17 feet, I cannot find how to adjust the shaft (body) of the column so that it falls between the base and the captial. Can anyone please help me.
Wed, Nov 28, 2007 at 8:52:00 AM | column Doric, the shaft extends beyond top capitel
aandr001
4.5 Stars: 6 Votes
If this is the doric column that is standard in the revit library, I selected the column, clicked on "Attach", clicked on "Top", and then selected a surface that I wanted to define the height of the column, in my case a ceiling.  This brought the whole column down to that height.  The column that I'm referring to has no height parameter in the properties menu.
How to extend top flange of beam (over top of column)?
Fri, Jun 15, 2012 at 10:35:08 AM
How do you align top of beam with top of column?
Wed, Feb 11, 2009 at 8:19:29 AM
Top of Isolated Column Footing forced to snap to bottom of column
Mon, Jan 13, 2014 at 7:41:43 PM
Shaft Problem
Thu, Jul 12, 2012 at 5:20:52 PM
How do you create a column that the proportions adjust to the height
Wed, Feb 25, 2009 at 8:54:53 AM
Page generation time: 0.2405
