Forums >> Revit Building >> Technical Support >> Target size of Spot Elevation (Revit Architecture 2008) 2
Mon, Nov 26, 2007 at 1:58:42 PM | Target size of Spot Elevation (Revit Architecture 2008) 2
rat69
Hi everybody, I need to create a symbol (block) of the standard "Spot Elevation" (Drafting / Spot Dimension / Spot Elevation) that is 50% of the original size. I don't understand how this works because the symbol that is supose to be used by the program "Spot Elevation - Target Filled" only shows the "Filled" area of the Target. I created a copy of this file with a 50% reduction and loaded it in my file, but now I have a Standard sized Target with a 50% size filled area. Does anybody knowa how to reduce the Target itself (crosshair and circle)? Or how to create a new symbol with a diferent size? I will really apreciate your help.
Thu, Dec 18, 2008 at 11:21:25 AM | Target size of Spot Elevation (Revit Architecture 2008) 2
Murphyj
Did you ever get your question answer?  If not it sounds like you need to go into the visibility graphics (VV) and go to the annotation categories tab and check the box next to the Show all annotation categories in this view.  This should turn on the crosshairs so you can scale them down.
Wed, Aug 6, 2008 at 9:43:56 AM
Spot Elevation without Target
Fri, Mar 20, 2009 at 4:57:55 PM
Spot elevation target symbol
Wed, May 27, 2015 at 5:09:17 PM
elevation target arrow head
Thu, Apr 3, 2014 at 1:21:54 PM
spot elevation symbol size
Fri, Mar 23, 2018 at 4:43:23 PM
Page generation time: 2.4660
