27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> I can't insert a window family that I created.
1 Posts No Rating |
I have created a window family called "Window_Office_EW_A" and it will not insert into a wall in my project. I get the following notices in the warning pop up window: Error - Can't make type "Window_Office_EW_A". Warning - None of the created elements are visible in Floor Plan: Level 2 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings. Any thoughts on how I might resolve this?
Quite likely that the wall you are trying to insert the window into is not wide enough to accept the family. How thick is the wall? Edit the family you created and make the sample piece of wall more narrow- adjust any constraints / parameters accordingly. Reload into project. Regards, Ian
www.RevitZone.com News / Articles / Tutorials / Forums / Beginners Guide to Revit |
Suddenly can't insert window in project............ |
Wed, Aug 3, 2016 at 11:36:50 AM
13
downloaded the window AC but can't insert it |
Mon, Oct 2, 2006 at 9:29:34 AM
Window family doesn't cut properly in plan |
Wed, Aug 5, 2015 at 6:44:07 AM
Window's dimension don't show up in the window schedule |
Fri, Aug 17, 2012 at 1:34:43 PM
Daylight Family |
Sat, Aug 27, 2005 at 8:44:08 AM
