Forums >> Revit Building >> Technical Support >> Levels and View Planes
Mon, Nov 26, 2007 at 10:47:01 AM | Levels and View Planes
superelboogie
I have a strange problem. I have a file that the frist floor is saying that its associated level is the second floor and the view range is set to the second floor levels BUT its showing the first floor!?!? So my cut is set to -4'. its very strange and its causing some random problems and confusion. the second floor is associated to the second level and has the same view range settings as the first floors screwy settings BUT it shows the second floor. Its really stange! We apply view templates to set the visibilities up and we cant do it with this one because it them sets the view range to the second floor. What do you think happened and is there a way to change the associated level?
Mon, Nov 26, 2007 at 10:56:06 AM | Levels and View Planes
OktoberFire
OktoberFire Avatar
when you right click> view properties, is underlay set to 2nd floor or None?
Mon, Nov 26, 2007 at 11:01:13 AM | Levels and View Planes
superelboogie
its set to none. no unerlay
Tue, Oct 14, 2008 at 12:27:05 PM | Levels and View Planes
djstarr14
I have the same problem. Have you figured this out?
Replacing levels with ref planes or deleting excess levels
Thu, Apr 17, 2008 at 11:10:37 AM
multiple levels in same view plane
Tue, Nov 11, 2008 at 7:38:38 AM
2 Out of 6 Reference Planes are not visible
Sun, Jul 13, 2008 at 4:52:58 AM
Wish List - Toggle Reference Planes
Fri, Sep 24, 2010 at 1:23:59 PM
Levels missing Revit 2012 [ 1 2 ]
Mon, Sep 28, 2015 at 3:29:41 PM
19
Page generation time: 0.6801
