Forums >> Revit Building >> Technical Support >> When to pin, When to lock - Best practices
Mon, Nov 26, 2007 at 10:35:05 AM | When to pin, When to lock - Best practices
jrotella
jrotella Avatar
3.5 Stars: 2 Votes
I have a lot of people here at my work always asking me when they should pin things, versus when they should lock things and I can't always give them a general answer to that question.  Anyone want to share their best practices on when to pin and when to lock?
 Thanks.
Tue, Nov 27, 2007 at 8:43:11 AM | When to pin, When to lock - Best practices
Okiaer
Its difficult to say, but I use this:
I use pin on the grid.
If you change the length of a wall, it will expand to both sides. I use the pin if I need the wall to expand one way.
Use pin if the object must not move.Use Lock when to objects needs to be moved together.
Hope it helpes
"Lock/Pin" Linked Architectural Model
Fri, Feb 11, 2011 at 10:13:52 AM
How to lock walls so they move together
Tue, Dec 21, 2010 at 12:45:46 PM
Revit Groups Best Practices
Tue, May 21, 2013 at 7:58:50 AM
Best Practices for extracting Bill of Quantities
Mon, Apr 11, 2016 at 3:07:28 AM
Pin Position
Tue, Oct 16, 2007 at 4:01:43 AM
Page generation time: 0.0559
