Forums >> Revit Building >> Technical Support >> Wall Sweep/Siding up to Roof Line
Thu, Nov 22, 2007 at 11:24:57 AM | Wall Sweep/Siding up to Roof Line
rcobbjr
3.5 Stars: 3 Votes
In Revit 2008, a wall with several components. The final component is a sweep with several profiles used to simulate hardiplank siding. On walls with a gable roof pitch, the siding does not go all the way to the top of the roof line. The sweep component stops at the top of the wall (not to the roof line). Any suggestions on how to cover the entire height of the wall from the foundation to the roofline?
Thu, Nov 22, 2007 at 5:57:14 PM | Wall Sweep/Siding up to Roof Line
lab21
Haven’t played around with the exact situation but have had similar problems before. To overcome them I changed the height of my wall so it was higher than the roof and instead of joining the top of the wall to the roof I edited its profile to match the roof line. I not sure if this if the best way to solve it but it worked for me. HTH, Luke
Thu, Nov 22, 2007 at 5:58:53 PM | Wall Sweep/Siding up to Roof Line
lab21
Fri, Nov 23, 2007 at 11:09:49 AM | Wall Sweep/Siding up to Roof Line
rcobbjr
3.5 Stars: 3 Votes
This is how I resolved it. I changed the top constraint of the wall to a level beyond the roof line. Then I attached the wall to the roof line. This resolved the problem. So ultimately I did the same thing you mentioned. Of course I got warnings when I did it so I don't know how that is going to impact the other information in the wall. But for right know it gives me the graphics that I need. Thanks for the information.
Wall Sweep ending at roof slope/roof line
Wed, Nov 21, 2007 at 11:07:34 PM
Siding Sweep Return
Sun, Oct 30, 2011 at 5:57:53 AM
Wall Sweep/Siding
Sun, Feb 17, 2008 at 12:11:00 PM
Cut wall sweep in line with top of angled wall?
Sat, Oct 15, 2016 at 11:38:08 AM
Bevel Siding
Fri, Apr 8, 2016 at 9:23:23 AM
Page generation time: 0.9080
