Forums >> Revit Building >> Technical Support >> Void extrusion wont cut mass
Wed, Nov 21, 2007 at 2:47:25 PM | Void extrusion wont cut mass
revitiw
I'm trying to cut a mass with a void extrusion,  but i keep getting a warning saying  "Can't keep elements joined."  it happens when finishing the sketch or using the cut geometry tool.  If i try to finish the mass i get another warning "This Mass has no solid geometry for its Void Forms to cut. They must be deleted, or solid geometry added and cut."
Wed, Nov 21, 2007 at 4:41:28 PM | Void extrusion wont cut mass
eldados
eldados Avatar
4.5 Stars: 8 Votes
not sure how you are doing it but first
create your mass geometry as a solid, than create the void to cut out.
this should work
Integrator
KarelCAD
Wed, Nov 21, 2007 at 4:58:47 PM | Void extrusion wont cut mass
revitiw
I created the solid extrusion first,  then cut it with one void on the south view.  Its the second void which is giving me problem,  I drew the sketch on the west view,  and keep getting the error messages.
Wed, Nov 21, 2007 at 5:07:27 PM | Void extrusion wont cut mass
eldados
eldados Avatar
4.5 Stars: 8 Votes
are you sure that the void is actually cutting through the mass?
when you finish your solid part, do not finish the sketch, stay in the sketch and draw your void.
Integrator
KarelCAD
Wed, Nov 21, 2007 at 11:27:01 PM | Void extrusion wont cut mass
revitiw
Yeah it was cutting through,  if i moved it off my solid I wouldn't get the message.  I reaized after i could copy and then revolve my first void and that worked out for me.  I tried your way after and it worked to.  I'm just new with revit,  really liking it,  trying to figure it out.  Thanks for the help.
Void Won't Cut Extrusion
Wed, Feb 13, 2013 at 11:04:26 AM
Cut a void from an extrusion
Thu, Feb 19, 2015 at 1:08:44 AM
Void Sweep won't cut extrusion
Fri, Aug 24, 2012 at 3:02:42 PM
Void Extrusion in window family problem
Mon, May 18, 2015 at 3:55:23 PM
void extrusion not cutting solid extrusion
Fri, Oct 10, 2008 at 3:47:43 PM
Page generation time: 1.0005
