Forums >> Revit Building >> Technical Support >> Multi-plane sweeps
Wed, Nov 21, 2007 at 2:23:35 PM | Multi-plane sweeps
rascal
I'm trying my darndest to model up a sweep on a 3D path - with no luck!  Is it entirely impossible to model up the bentwood Thonet chair, or make a lovely undulating pipe in space in Revit right now?  Any ideas on a workaround (within reasonable simplicity) if so?  aahh!  help!!
-r
Thu, Nov 22, 2007 at 7:54:55 AM | Multi-plane sweeps
coreed
coreed Avatar
4 Stars: 16 Votes
is this the chair. i have also included a sketchup model of the chair from Google 3D Warehouse that you can import into Revit to use as a guide for creating your model.
HTH
Edited on: Thu, Nov 22, 2007 at 7:55:31 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Nov 23, 2007 at 7:57:50 AM | Multi-plane sweeps
Take a good look at this family.  It has 3d (4 plane) sweeps in it.
http://www.revitcity.com/downloads.php?action=view&object_id=3250
I have played around with this family and modified it.  I'm still not 100%  confident in how to do these complicated sweeps but they can be done.
Integral Wall Sweeps
Wed, Mar 12, 2008 at 3:44:55 PM
Problem connecting wall sweeps (horizontal and vertical)
Fri, May 4, 2012 at 2:07:26 PM
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:41 PM
Multi Monitors
Tue, May 1, 2012 at 1:29:09 AM
Walls with automatic wall sweeps
Fri, Aug 31, 2012 at 3:58:55 AM
Page generation time: 1.0535
