Forums >> Revit Building >> Technical Support >> Adding quarter round moulding to existing base board moulding
Tue, Nov 20, 2007 at 8:43:48 PM | Adding quarter round moulding to existing base board moulding
rcobbjr
3.5 Stars: 3 Votes
I am using Revit 2008. I have added 5-1/4" x 9/16" base moulding to the walls using the Wall Sweep command. I want to add 11/16" quarter round to the 5-1/4" x 9/16" base moulding. When I try it, Revit seems to honor only one wall sweep. When I try to add the quarter round moulding to the already existing base moulding, the original base moulding disappears. This leads me to believe that Revit will only allow one wall sweep to be present at the time. Am I wrong? Is it possible to add the quarter round moulding to the already 5-1/4" base moulding? If so, please advise.
Curtain wall not cutting through moulding
Thu, Oct 22, 2015 at 2:53:44 PM
Help with a single stone moulding window
Thu, Aug 18, 2005 at 3:31:42 AM
baseboard moulding
Fri, Jan 27, 2017 at 10:40:33 AM
Crown Moulding Return
Thu, Aug 22, 2013 at 2:52:28 PM
Profile to path and Material quantity
Fri, Apr 5, 2019 at 10:49:15 AM
Page generation time: 0.2446
