Forums >> Revit Building >> Technical Support >> FAMILY EDIT - adding hidden lines to casework to show shelves in elevation
Tue, Nov 20, 2007 at 12:07:42 PM | FAMILY EDIT - adding hidden lines to casework to show shelves in elevation
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Ok, I've been messing with this one for awhile now.  I am trying to add hidden symbolic lines to my cabinets to resemble shelves inside the casework.  I have set up reference planes to lock to the sides of the cabinet.  Then I set up my symbolic lines and locked the ends to the Ref planes.  Then I use Array and specify how many I want to add.  I lock the top symbolic line to the bottom of the cabinet (just to hide it) and same with the top line.  Then in the parameters I have one titled: "Number of Shelves" (instance integer), and another one titled "##" (instance integer).  The ## is the number of symbolic lines including the two that are locked to the top and bottom.  The other one is set to = ## - 2.  This gives the user the ability to type the number of shelves in without needing to worry about the two hidden lines.  This works great and I can add 100 shelves or 3 and it adjusts when the Height is changed.  But when I change the width, the shelves  don't follow.  I can't figure out why.  Because the reference planes are locked to the width.  Before I array my lines and they becomed grouped items, I can change the width and it works fine.  But without the grouped array I can't use the integer parameter to allow users to change the number of shelves.
 So does anyone know what I am doing wrong?  I have tried all ideas from crontroling the shelf width (which doesn't work either) to playing with the interger parameters.  Please help!
 Thanks in advance,
Lorne
Denver, CO
Revit Architecture
Tue, Nov 20, 2007 at 12:10:11 PM | FAMILY EDIT - adding hidden lines to casework to show shelves in elevation
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Here's the file if my description wasn't confusing enough Puh
Denver, CO
Revit Architecture
Tue, Dec 4, 2007 at 3:39:46 PM | FAMILY EDIT - adding hidden lines to casework to show shelves in elevation
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Anybody please?
Denver, CO
Revit Architecture
Mon, Feb 11, 2008 at 1:24:17 PM | FAMILY EDIT - adding hidden lines to casework to show shelves in elevation
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
I need to resurface this...still haven't figure out how to accomplish this.  I just basically need to know how to Array lines as a group and set a family parameter to edit the number of lines it shows.  Then lock the ends of the lines to an object.  If the object changes width the lines follow.  I can't get it to work.  Thanks.
Lorne
Denver, CO
Revit Architecture
Tue, Feb 12, 2008 at 3:21:50 AM | FAMILY EDIT - adding hidden lines to casework to show shelves in elevation
GunawanArthur
4 Stars: 4 Votes
Try this one,
Create a family containing only one symbolic line, with width parameter. And nested it to your main family, and link the component width with the main family width,
I attached my small experiment, and it looks correct.
Best regards,
Arthur Gunawan
Edited on: Tue, Feb 12, 2008 at 3:24:51 AM
Revit Architecture 2011
Revit Family Casework looks different from 3d view to elevation
Mon, Nov 13, 2017 at 4:38:23 PM
shower enclosure & casework visiblity
Sun, Nov 5, 2006 at 12:53:09 PM
Hidden lines in elevations
Mon, Sep 10, 2007 at 9:43:06 AM
Casework below in-place component won't show - R09
Fri, Dec 4, 2009 at 11:50:12 AM
Elevation/Creating Hidden lines
Fri, Mar 12, 2010 at 12:43:17 PM
Page generation time: 1.3725
