Forums >> Revit Building >> Technical Support >> casework in RCP
Mon, Nov 19, 2007 at 4:42:22 PM | casework in RCP
mlohr
mlohr Avatar
we have some casework that is 7' tall and is showing in the Reflected Ceiling Plan.  I have tried editing the family and turning off the view in Floor Plan/RCP visibility options without noticable change. Our office is using Revit 2008.  Any advice out there?
Fri, Nov 23, 2007 at 8:30:30 AM | casework in RCP
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Try checking the View Range. Most likely your Cut plane is set to 7'-0" or lower. If so set it to above the height of the tallest cabinet. If this is not the issue then check to see if you have an underlay turned on. This is found in the View Properties.
Fri, Nov 23, 2007 at 8:43:13 AM | casework in RCP
If anything in the family is cut by your view plane .... including invisible lines, the family will show.
If all else fails - you can always just hide the element.
Low elements in a casework family showing up in RCP (Revit Architecture 2012)
Tue, Feb 5, 2013 at 1:42:21 PM
Phantom Casework
Tue, Aug 28, 2012 at 12:25:48 PM
Casework below countertop not visible.
Wed, Jan 27, 2010 at 2:16:58 PM
Lower casework showing through when touching counter?
Wed, Mar 6, 2013 at 9:38:23 AM
2D light family shows too big on RCP legend
Wed, Jul 3, 2013 at 11:35:44 AM
Page generation time: 0.0362
