Forums >> Revit Building >> Technical Support >> Vertical reveal spacing in a curved wall
Mon, Feb 21, 2005 at 8:11:35 PM | Vertical reveal spacing in a curved wall
kfpopeye
Is there a quick way to place vertical reveals at 5'-0" o/c around a curved wall?
Mon, Feb 21, 2005 at 8:47:16 PM | RE: Vertical reveal spacing in a curved wall
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Not really... I'd probably draw a detail line arc at the same radius as the wall, calculate the correct length of the segment using x/360º*(2*piRolling Eyes) to work out the angular length of the segment then place the reveals at these points... HTH.
Mon, Feb 21, 2005 at 9:08:18 PM | RE: Vertical reveal spacing in a curved wall
kfpopeye
I take it Revit doesn't have a command like AutoCAD's "measure" command?
How to do a vertical reveal in a sweep in a curved wall?
Thu, Oct 22, 2009 at 2:04:26 PM
vertical wall reveal troubles
Wed, May 6, 2009 at 3:22:52 PM
How do i make a foam wall with repeating vertical reveal
Sat, Nov 18, 2017 at 10:50:48 PM
Precast panels and vertical reveals
Thu, Jan 17, 2013 at 9:38:52 AM
Wall reveal - Vertical
Wed, Sep 2, 2009 at 10:54:59 AM
Page generation time: 3.1663
