Forums >> Revit Building >> Technical Support >> Revit 2008 - changing pattern overscaling color from gray lines to black
Mon, Nov 19, 2007 at 6:39:51 AM | Revit 2008 - changing pattern overscaling color from gray lines to black
rop28600g
Greetings,
Does anyone can help me change the pattern overscaling from gray lines or solid fill to black?I am realizing a template file with drawing properties for every often used scales in a architecture project. I have discovered that when working with very small patterns Revit degradates them to gray lines when I want them black, instead. It's called pattern overscaling and I can´t find answer for this anywhere. This is important for colored drawings. Because when I print in black lines the pattern lines turns out ok. In black.
Thanks.
Tue, Nov 20, 2007 at 6:25:40 AM | Revit 2008 - changing pattern overscaling color from gray lines to black
rop28600g
Here goes two examples. Notice that in the printed in color sheet the pattern turnbs out gray. All the settings for pattern, material or filled region are black. This happens both in model and drafting surface patterns. This a serious bug for our work in the office. Thanks.
Material Surface pattern changes to gray with view scale
Wed, Apr 27, 2011 at 2:05:06 PM
Print color lines in Black
Fri, Aug 8, 2008 at 11:15:34 AM
Material hatch will not print gray, only black
Thu, Jul 14, 2011 at 8:16:53 AM
line color doesnt apply in mep 2013
Fri, May 10, 2013 at 10:54:14 AM
Existing Walls Printing Black (SHOULD BE GRAY)
Tue, Mar 27, 2007 at 12:42:28 PM
Page generation time: 1.7197
