Forums >> General Discussion >> Revit Project Management >> Fittings assigned to room outside the room area?
Mon, Nov 19, 2007 at 4:57:02 AM | Fittings assigned to room outside the room area?
Gils
Is is possible assigning a fitting, for example electrical fixture (light switch) to a room area that behind a wall? Mainly this is to do with scheduling and material takeoff.
Mon, Nov 19, 2007 at 10:18:09 AM | Fittings assigned to room outside the room area?
IDN101
2.5 Stars: 3 Votes
You can assign a fitting whever you wish. Whatever Room it falls within- it will be associated with in schedules.
Create use of Room Seperation lines and "Room Bounding" properties, will probably achieve what you after (which I'm not exactly sure of!)
Regards,
Ian
www.RevitZone.com
News / Articles / Tutorials / Forums / Beginners Guide to Revit
Mon, Nov 19, 2007 at 10:43:47 AM | Fittings assigned to room outside the room area?
I think REVIT determines where something is from it's origin.   I've had to work out problems where invisible lines place an object in the next rooms schedule.  I've not had time to completely discover the rules but I've fixed my issues.   If you go this route, you might want to create this as a seperate family so that it isn't confused with the correct one.
Room tag not showing in only one room. [ 1 2 ]
Sat, Sep 27, 2025 at 3:40:00 AM
15
Room Bounding - Room area changes, then changes back for no reason!
Wed, Apr 28, 2010 at 6:22:40 PM
Room area calculation
Sun, Nov 25, 2012 at 2:28:44 PM
changing the scale of my room and area tags with the scale of my area plan.
Fri, Oct 22, 2010 at 10:38:38 AM
room area calculation
Thu, Jan 15, 2009 at 5:51:20 AM
Page generation time: 0.2183
