Forums >> Revit Building >> Tips & Tricks >> help!...adding people to renderings.
Mon, Feb 21, 2005 at 2:26:32 PM | please help!...information about adding people to renderings.
ggualajara
4 Stars: 1 Votes
can anyone please help me. please explaining any technical information for adding people to a rendering. i know that i can import a model family of a person but how can i imported an image of a person , or how can i import a rpc file into a view ? does the image attach to a previously imported model family?.. any information will be helpfull thank you... +ggjg Post edited on 2005-02-21 16:03:53 Post edited on 2005-02-21 16:04:35
Mon, Feb 21, 2005 at 6:25:40 PM | RE: help!...adding people to renderings.
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Load Family-->locate Rpc male.rfa and RPC Femal.rfa and load them into the project. You can then go to the properties of these families and change the rpc file to any rpc that you have... They will then on show when rendering. HTH.
Wed, Feb 23, 2005 at 12:15:20 PM | RE: help!...adding people to renderings.
ggualajara
4 Stars: 1 Votes
WHERE CAN I FIND THOSE FAMILIES?, i think i dont have them on the template library.... do i have to create them?...... and how? thanx +ggjg
Wed, Feb 23, 2005 at 5:22:57 PM | RE: help!...adding people to renderings.
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
They should be located wherever you installed your default metric or imperial library... In the entourage folder... The RPC files are located in the rendering folder...
Wed, Feb 23, 2005 at 5:38:17 PM | RE: help!...adding people to renderings.
ggualajara
4 Stars: 1 Votes
found them!..., thank you so mucho , i alreday made a render practice of it...... is there any place that you recomend for rpc people images ?......... thank you again. +ggjg Post edited on 2005-02-23 18:17:51
Wed, Feb 23, 2005 at 7:15:41 PM | RE: help!...adding people to renderings.
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can buy RPC images from www.archvision.com, not cheap... You can also make your own. Check out the Tutorial to learn how...
Adding People To My Revit Rendering
Fri, Oct 7, 2016 at 1:54:43 PM
Showing people in renderings
Wed, Apr 23, 2008 at 8:13:20 AM
using RPC People in Renderings
Mon, Dec 18, 2006 at 11:16:31 AM
Rendering People
Wed, Jan 9, 2013 at 2:41:25 PM
People in Render
Thu, Jun 15, 2006 at 9:02:26 PM
Page generation time: 0.1996
