15 Users Online (13 Members):
Forums >> Revit Structure >> Tips & Tricks >> Multiple Leader Text
When wanting to place text with multiple leaders. Just place the text without a leader. Then select the Modify tool and select the text. In the Options Bar you will see add leader. just select the type of Leader leader that you want, left or right, straight or arched. Each time you click add-leader, Revit will add a leader. Each time you click Remove Leader Revit will remove a leader in the reverse that they were placed. HTH
Edited on: Sun, Nov 18, 2007 at 12:35:05 PM
Multiple leader types for single text element |
Thu, Aug 9, 2018 at 7:53:19 AM
ARC LEADER NO TEXT |
Thu, May 2, 2013 at 10:36:04 AM
Distance from leader to text... Revit 2010 |
Tue, Jun 1, 2010 at 9:13:51 AM
distance between text and leader lines able to be changed? |
Fri, Sep 12, 2008 at 10:20:21 AM
drawing a leader/arrowhead without text? |
Mon, May 31, 2010 at 10:54:51 AM
