Forums >> Revit Building >> Technical Support >> Ground Plane in Rendering
Mon, Feb 21, 2005 at 1:30:50 PM | Ground Plane in Rendering
SD Binc
When rendering 3d View, I get a mysterious ground plane - even when that toggle is shut off in the Rendering Scene Settings/Environment/Advanced dialog box. The plane looks to be at elevation 0 and is s solid grey - which obscures the actual topo below which is green lawn. I don't see this plane in any other view except when I attempt a raytrace. Any suggestions? SD Binc
Mon, Feb 21, 2005 at 6:22:03 PM | RE: Ground Plane in Rendering
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
There are two areas where a ground plane can be turned on check them both... In Rendering scene as mentioned, But also in Advanced model graphics\sun & shadow settings... Make sure its unticked here.
Tue, Feb 22, 2005 at 2:25:54 PM | RE: Ground Plane in Rendering
SD Binc
Thanks Mr. Spot. There are so many toggles- so little time! Chow SD Binc Post edited on 2005-02-22 14:26:53
Rendering - Changing Ht of Ground plane does not 'stick'
Thu, Mar 10, 2005 at 4:35:08 PM
Rendering Ground Plane
Wed, Oct 4, 2006 at 1:00:19 PM
Rendering Ground Planes showing up when i dont want them to
Wed, May 10, 2006 at 7:14:43 AM
ground plane rendering
Thu, Aug 16, 2012 at 11:54:38 AM
Rendering problems Ground plane not changing
Wed, Mar 7, 2012 at 1:42:46 PM
Page generation time: 0.2696
