Forums >> Revit Building >> Technical Support >> Adding Parameters to Custom Family
Fri, Nov 16, 2007 at 12:58:40 PM | Adding Parameters to Custom Family
Volorgas
I have created a new, custom family for a concrete foundation wall.  The family contains a graphic that was imported from autocad (see attached image).  How can I add a parameter to the family that will allow this graphic to look like concrete (using pattern fills for cuts and surfaces)?  Thanks.
Adding Shared Parameters to Families
Tue, Apr 24, 2012 at 6:00:18 PM
Adding Base/Top Constraint to Family Member
Wed, Sep 9, 2009 at 5:16:39 PM
Filtering by user defined parameters.
Fri, Oct 19, 2007 at 10:04:51 AM
Custom parameters in view titles
Mon, Sep 24, 2007 at 6:49:51 PM
Mystery parameters - shared?
Tue, Nov 10, 2015 at 7:06:20 AM
Page generation time: 2.6330
