Forums >> Revit Building >> Technical Support >> Clean cut below stairs.
Fri, Nov 16, 2007 at 10:23:45 AM | Clean cut below stairs.
naranjo01
naranjo01 Avatar
1 Stars: 2 Votes
Hi pals,
How I clean a joint with concrete wall and monolitic stair cut in section plane, like clean cut when attach a wall to floor?
thanks.
Sat, Nov 17, 2007 at 4:19:15 AM | Clean cut below stairs.
coreed
coreed Avatar
4 Stars: 16 Votes
try using the "Edit Cut Profile" tool. here is a link to a  tutorial from CadClips that explains how to use the tool.
http://www.cadclips.com/downloads/REVIT-9-DETAIL-EDIT-CUT-PROFILE.wmv
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Nov 30, 2007 at 8:56:15 AM | Clean cut below stairs.
naranjo01
naranjo01 Avatar
1 Stars: 2 Votes
Thanks corred for your tip, but I can't manage to clean lines in elevations
The edit cut profile works great in details since the scope box hide the mess, but in full elevations views I can't find the way, yet.
Stairs and plan regions (cut height)
Mon, Apr 21, 2014 at 10:22:57 AM
cut symbol on stairs
Sun, Dec 4, 2011 at 8:21:55 AM
Revit 2013 - Cut Wall under stairs.
Thu, Oct 18, 2012 at 3:23:10 AM
Plan Region & stairs
Thu, Jun 18, 2009 at 1:28:36 PM
Stair - Cut Profile
Wed, Sep 14, 2011 at 1:36:18 AM
Page generation time: 3.3840
