Forums >> Revit Building >> Technical Support >> Attached detail groups missing from model groups...
Fri, Nov 16, 2007 at 9:42:24 AM | Attached detail groups missing from model groups...
chiarch15
I am using Revit 2008, we are working on a residential project.  I have grouped individual apartment units together and now I have created detail groups for each that include drafting items such as filled regions.  In the browser I see the model group listed and the detail group attached, however...every where the model group shows up the attached detail group does not.
 How can I get the desired attached detail group to show up with the designated model group through out the project?
Fri, Nov 16, 2007 at 10:06:15 AM | Attached detail groups missing from model groups...
yeror13
sorry
 this is not an answer but a question
i can't find the way to post a question in the forum
can you help me?
thanks
Mon, Aug 17, 2009 at 8:11:10 AM | Attached detail groups missing from model groups...
sparra
I had the same problem so here's the solution:
You need to change the visibility settings (VV) so that the group displays as "link by view", then select floor plan or whatever view you are in to add the detail group.
Array Groups within Detail Groups
Tue, Jul 9, 2013 at 7:34:32 AM
Detail Groups NOT DELETING!
Thu, Apr 2, 2009 at 4:03:47 PM
Model Pattern in Mirrored Groups
Fri, Apr 17, 2009 at 5:23:13 AM
Model Groups
Fri, Oct 13, 2006 at 7:31:56 PM
Details groups locked to model elements, possible?
Mon, Aug 29, 2011 at 7:23:05 PM
Page generation time: 2.1722
