18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Independent window families
7 Posts No Rating |
Our company specialises in precast architecture, we are currently trying to implement a new system of drawing panels. Key to this new system is the ability to create windows and doors that are not dependent on a wall. What is the easiest way to create these independent families? Currently using Revit: Architecture 2008
7 Posts No Rating |
Problem solved. Model the window as a generic model and switch family type to window.
You could also (of course) just create them using a Window template and then turn off the visibility of the wall as you view it. Just another option. Regards,Ian
www.RevitZone.com News / Articles / Tutorials / Forums / Beginners Guide to Revit |
7 Posts No Rating |
I had a quick go at your method, im not sure i completely understand it?
" You could also (of course) just create them using a Window template and then turn off the visibility of the wall as you view it. Just another option. Regards,Ian " This method won't work, because the Window template is a wall hosted template. Therefore you have to have a wall to place the window in on a project.
independent view range |
Wed, Dec 22, 2010 at 7:32:10 PM
window families |
Mon, Nov 28, 2005 at 6:43:56 PM
Independent Investment Planning |
Wed, Jan 28, 2026 at 7:05:22 AM
WINDOW FAMILIES |
Thu, May 24, 2007 at 5:46:09 PM
Better Window Families |
Tue, Aug 30, 2005 at 4:25:33 PM
