Forums >> Revit Building >> Technical Support >> Hide the elevation circles from floor plan
Thu, Nov 15, 2007 at 9:26:03 AM | Hide the elevation circles from floor plan
OktoberFire
OktoberFire Avatar
can these been hidden when i put my floor plans on a sheet?
 if i edit them on the Floor Plan it deletes my north etc elevation view
Thu, Nov 15, 2007 at 10:19:30 AM | Hide the elevation circles from floor plan
TJKENNEDY
3 Stars: 2 Votes
If you are not putting the elevation view on a sheet, you can plot without showing unreferenced view tags. You will still see them in Revit, but they will not plot.
If you dont want to see any elevation callouts, you can turn them off in Visibility/Graphics.
If you are using 2008, you can select the tag, right click and select "hide element" to hide individual tags.
Thu, Nov 15, 2007 at 10:45:04 AM | Hide the elevation circles from floor plan
OktoberFire
OktoberFire Avatar
thank you, once i've hidden them how would i get them showing again Smile
Thu, Nov 15, 2007 at 11:00:48 AM | Hide the elevation circles from floor plan
TJKENNEDY
3 Stars: 2 Votes
The show hidden elements button at the bottom of the view window. It's the light bulb next to the scale, detail level etc. buttons. When you click it your hidden elements will show up and you can edit them without unhiding them, or you can unhide them so they will show up.
Thu, Nov 15, 2007 at 11:07:46 AM | Hide the elevation circles from floor plan
OktoberFire
OktoberFire Avatar
excellent!
thanks for the help Smile
Elevation Level Marker Associated To Wrong Floor Plan
Wed, Feb 25, 2015 at 10:44:23 AM
Floor plan visibility: All equipment on the floor below are showing!
Wed, Nov 4, 2015 at 7:32:48 AM
Hiding selected section/detail annotation floor plan and elevation
Wed, Oct 2, 2013 at 10:28:28 AM
How can I hide a portion of something from floor plan view?
Wed, Apr 18, 2012 at 4:22:59 AM
Revit's collor fill hides floor slab floor slab doesnt hide stairs anymore
Thu, Feb 8, 2007 at 2:08:28 PM
Page generation time: 1.5002
