9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Different Wall Colours in separate views.
8 Posts No Rating |
I've got a wall type dwg. & a wall acoustic properties drawing. How do I make the same wall show up different colours in each drawing?
18 Posts No Rating |
Select the object you want to change the color to and then right click there will be a option to override graphics if you select that then do just the element you can change the line types, wall patterns, and colors there. That is the only thing I can think of. I use that way alot. Hope that helps -Stephanie
Different wall colours in plan |
Tue, Aug 1, 2006 at 10:46:38 PM
AutoCAD line colours |
Mon, Dec 14, 2009 at 11:38:47 AM
RAL colours |
Fri, Sep 11, 2015 at 3:32:21 AM
help with family parameters to show colours in elevation views. |
Tue, Nov 30, 2010 at 7:14:20 AM
Colours |
Sun, Feb 14, 2010 at 7:40:31 AM
