Forums >> Community >> The Studio >> Revit Flyarournds
Wed, Nov 14, 2007 at 1:29:07 PM | Revit Flyarournds
baapple
I'm having difficulty in creatind a building "fly-around" in Revit. Can anyone assist me?
Thu, Nov 15, 2007 at 10:00:49 PM | Revit Flyarournds
ale02
ale02 Avatar
3 Stars: 3 Votes
I think this thread should be best disscussed in Revit Building or The Studio but nevertheless...
My usual way of flyarounds/ walkthru is carried out by assigning another new bird eye view level (usually higher that roof level & depends on the size & dimensions of your project/ building).
Sketch the walkthru path in bird eye view level and change the view depth and camera angle to what you intend to view along the way
Then open the walkthru view and adjust your camera frame and angle by using dynamic rotate tools.
You might need to adjust back and fore between plan (for path and keyframe) and camera (viewing angle) view to get your best flyaround or walkthru.
If you are intended to produce a flydown walkthru, it might be a little bit trickier as you have to adjust your sketched keyframe in elevation.
Hope this helps.
Life is never easy but nor it should be complex. Just stay simple Smile
Revit for Construction Documents [ 1 2 ]
Tue, Jan 24, 2012 at 10:57:38 AM
20
4D simulation in Revit? [ 1 2 ]
Mon, Jan 17, 2011 at 11:27:39 AM
18
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ]
Thu, Jan 6, 2011 at 3:25:02 PM
18
We are looking for Revit Users [ 1 2 ]
Thu, Mar 31, 2011 at 5:15:24 PM
17
AutoCad vs Revit [ 1 2 ]
Thu, Aug 4, 2011 at 1:58:52 PM
16
Page generation time: 5.7656
