27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Printing/Plotting Problems
I am using Revit 2008 and have created some construction documents for my project. When I print the drawings, some views have "information" such as lines missing. In some cases the lines are cut off. The data light on the plotter will come on for some sheets that I print. This happens when I plot straight from Revit and when I convert the sheet to PDF and plot the PDF. Is this a "data crunching" problem? Can the problem be resolved by increasing the memory in the plotter? If these are not the solutions to the problem, can someone provide me with a solution or at least a work around? Thanks.
64 Posts No Rating |
what plotter do you have? with hp ones i know you can set the print job to computer memory, not plotter memory - this may cure your problems.
I have access to HP DesignJet 430 and 450C. Do you change the settings on the computer or the plotter itself? Thanks for the tip.
when you go to print, click the properties>advanced>Process Document ....put a tick in computer
plotting / printing |
Wed, Feb 13, 2008 at 8:31:12 AM
Plotting |
Tue, Jun 23, 2009 at 5:51:33 PM
Problems plotting |
Mon, Nov 9, 2009 at 3:38:20 PM
Revit Print Problems - UPDATE |
Fri, Sep 2, 2016 at 1:44:13 PM
Plotting Shadows |
Tue, Feb 17, 2009 at 6:54:48 PM
