12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Masking Regions
When creating a tag, you can add a "masking region". this seems to mask an area within the tag, but only in display, not in print. You can create a solid fill area with no line weight (in the tag), this produces what I would call a masking region. What's the purpose of "masking regions"?
Masking Regions are basically there to "mask out" something in a view that you don't want to see. Commonly used as a way of detailing complicated wall junctions in plan, for example. They can be 2D or 3D. Regards, Ian
www.RevitZone.com News / Articles / Tutorials / Forums / Beginners Guide to Revit |
Why don't they mask when I print? They do mask in the display.
8 Posts No Rating |
I have found it’s much easier to simply create a filled region with invisible lines, then give the filled region a solid white fill. That is the guarantee way to work.
Masking Regions and Filled Regions - Which Is In Front? |
Fri, Oct 28, 2011 at 2:26:55 PM
Exporting to Autocad with Masking Regions |
Thu, Apr 25, 2013 at 10:33:27 AM
11
Revit 2010 Masking Regions |
Mon, Nov 30, 2009 at 4:42:34 PM
Masking Regions not "masking" |
Mon, Dec 14, 2009 at 11:21:22 PM
masking regions |
Mon, May 11, 2009 at 4:31:49 PM
