15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Edit Line Types in family?
So I searched and couldn't find anything. But I am trying to fix the elevation door swing to be a dash, dot, dash line. When I got to the settings menu the Linetypes option is not selectable. I can only select Lineweights, and patterns. Is there a way to edit the linetypes so I can change the symbolic lines to the correct line pattern? thanks, Lorne
Denver, CO
Revit Architecture |
8 Posts No Rating |
I hope this answers your question. From what you just said, you want to change the door swing while editing the family from a solid line to a dash dot dash. Ok. If you go to line patterns, there is where you can select what type of line you wish to use.
8 Posts No Rating |
Ok here's more to my reply. - Type VG to get into your visibility graphics
- Select object styles
- You will see three tabs at the top: Model Objects, Annotation Objects, and Imported Objects. This is where you can select which lines you want to change, what thickness, etc.
Let me know if this helps you out.
Family types problem. |
Tue, Apr 21, 2009 at 10:00:20 AM
Family types - conditional statement |
Mon, Apr 18, 2011 at 3:59:50 PM
Changing line types and styles in cross section views, wall types etc... |
Wed, Apr 12, 2006 at 12:52:32 AM
Purging Line-Types |
Tue, Dec 12, 2006 at 6:41:21 AM
Detail Family Line weight sub-catoagories gone when family put into project |
Tue, Aug 30, 2016 at 6:52:17 AM
11
