Forums >> Revit Building >> Technical Support >> Newbie's problems help appreciated
Mon, Nov 12, 2007 at 11:54:44 AM | Newbie's problems help appreciated
SimonCSK
Hi have had Revit for a while but am now just being trained in its use. Have been to one training session out of 3 so have a long way to go. Second was posponed because the trainer was ill.
Problem is I have committed the Use of the programme for a clients project and am doing very well so far. I am at the roof stage with almost everything else done. When I put the roof on which is a traditional dual pitched roof I am getting stuck. Can any one give me an idiots guide to putting on my roof. I have the gables drawn in.
Assistance appreciated
Simon
Mon, Nov 12, 2007 at 11:56:20 AM | Newbie's problems help appreciated
SimonCSK
Sorry should have said 2008 version
TA
Tue, Nov 13, 2007 at 1:37:35 AM | Newbie's problems help appreciated
IDN101
2.5 Stars: 3 Votes
Can you tell us which bit exactly you are having a problem with.
In a nutshell:
-Make sure you're on an appropriate Level to start with
-Select "Roof"
-Choose a method for defining ie "By Footprint", "Using Sketch Lines", etc, etc
-Tell Revit about the roof you want (ie sketch it's plan, set slopes, set roof type, etc
 -Let Revit make the Roof
Regards,
Ian
www.RevitZone.com
News / Articles / Tutorials / Forums / Beginners Guide to Revit
Tue, Nov 13, 2007 at 9:26:30 AM | Newbie's problems help appreciated
SimonCSK
Ian
Thnaks for the reply.
Initially it was drawing a dual pitched roof but have resolved that from one of the other threads. The problem that I am still having is where one roof intersects with another forming the valley. Having drawn this I end up with the two roofs passing through on another.
Simon
Tue, Nov 13, 2007 at 11:07:28 AM | Newbie's problems help appreciated
IDN101
2.5 Stars: 3 Votes
Ignore my previous reply!
I've just knocked up a quick tutorial on my site, which should answer your question.
http://www.revitzone.com/index.php?option=com_content&task=view&id=721&Itemid=49
Regards,
Ian
www.RevitZone.com
Wed, Nov 14, 2007 at 5:54:13 AM | IDN101
OktoberFire
OktoberFire Avatar
Quoting IDN101 from 2007-11-13 11:07:28
Regards,
Ian
great site and tutorial, im new to revit and it seems so far the hardest part has been drawing roofs with soffits etc
i still havent mastered it yet though Sad
Wed, Nov 14, 2007 at 7:59:17 AM | Newbie's problems help appreciated
IDN101
2.5 Stars: 3 Votes
Soffits are no problem: Just enter the soffit width you want into the "Overhang" box (on the Options Bar, when you're in "Roof Mode"Winking.
Regards,
Ian
www.RevitZone.com
Wed, Nov 14, 2007 at 8:24:07 AM | Newbie's problems help appreciated
OktoberFire
OktoberFire Avatar
the main problem im having it getting the roof to align with the soffit and when i to on the brickwork, the roof sits within it.
also drawing soffits on gable ends, and how to do hip roofs
sooo much to learn
Wed, Nov 14, 2007 at 8:40:55 AM | Newbie's problems help appreciated
IDN101
2.5 Stars: 3 Votes
A good way to get upto speed with Revit is to read....
http://students2.autodesk.com/ama/orig/RAC-2008-CurriculaLectureNotes_Final.pdf
 Covers all the fundamentals.
 If you got anything specific on roofs you need help with- give me a shout and I'll try and squeeze in some extra step-by-step tutorials.
Regards,Ian
www.RevitZone.com
Newbie needs help
Mon, Dec 28, 2009 at 8:45:27 AM
Revit newbie - Few questions
Sat, Feb 9, 2013 at 10:50:07 PM
Having problems with my Project Browser, a newbie question
Mon, May 2, 2011 at 12:38:33 AM
Problems plotting
Mon, Nov 9, 2009 at 3:38:20 PM
Newbie - Can't view in 3d
Tue, Apr 1, 2014 at 9:24:52 AM
Page generation time: 4.7721
