Forums >> Revit Building >> Technical Support >> Electrical Fixtures Lineweight
Fri, Nov 9, 2007 at 2:02:03 PM | Electrical Fixtures Lineweight
rhughes
I am making a lighting plan, and the lineweight of the switches will not change even when I override the visibility setting for that view and set the electrical fixtures' lineweight to 3. In another plan view, showing electrical outlets, I've changed the same visibility settings, and the lineweights of the outlets show up correctly.
Using Revit Architecture 2008--
Am I missing something? Thanks!
Mon, Dec 8, 2008 at 1:22:12 PM | Electrical Fixtures Lineweight
jarosa
jarosa Avatar
4 Stars: 5 Votes
Similar problem. I want to change the lineweight for the electrical fixture symbols. I can change the light fixture lineweight via VG but not fixtures???
Mon, Dec 8, 2008 at 1:44:46 PM | Electrical Fixtures Lineweight
Edit your symbols family and look at what types of lines were used.  If they are generic annotations, then the lineweight is controlled under VG/annotations/generic annotations.  If you want siomething special, you could create a new sub-category ... maybe generic/electrical thin .... that could then be controlled seperately.
Mon, Dec 8, 2008 at 2:43:15 PM | Electrical Fixtures Lineweight
jarosa
jarosa Avatar
4 Stars: 5 Votes
W,
Thanks. I think i overrode a bunch of other objects but didn't see that one. I was even overriding objects that were nested in the family. Generic Annotations worked like a charm. Now if I'm thinking this thru correctly, when i override the object styles that will override Generic Annotations in all views...Correct?
thanks again,
John
Mon, Dec 8, 2008 at 3:11:41 PM | Electrical Fixtures Lineweight
If you do it in object styles, the result is project wide... otherwise VG is view specific.
Edited on: Mon, Dec 8, 2008 at 3:12:03 PM
Tue, Jul 21, 2015 at 12:39:00 PM | Electrical Fixtures Lineweight
mike102
3 Stars: 2 Votes
Another thing that could be an issue is to make sure to check your display model under your view template and it is turned to normal and not halftone.
printing electrical lauyout
Wed, Jul 7, 2010 at 11:05:50 AM
Electrical fixtures in plan
Mon, Nov 1, 2004 at 3:57:02 PM
Electrical Fixtures: Component families?
Tue, Sep 11, 2007 at 8:38:42 AM
symbolic lines
Thu, Jul 13, 2006 at 8:15:41 PM
Interior Elevations and Families
Tue, Jul 12, 2016 at 8:11:42 AM
Page generation time: 1.6973
