21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Stepping foundation wall to follow grade
2 Posts No Rating |
My site slopes and I need to step the concrete foundation wall to keep the stone veneer close to the grade line. I have created a stacked wall type with 12" concrete below and framing and veneer above. Do I need to split the wall vertically (in elevation view) and create a different wall type for each change in foundation wall height? Thanks for any guidance you can offer.
2 Posts No Rating |
By the way, I'm using Revit Architecture 2008. Laura
No, just put multiple walls of the same type end to end and join geometry. In that way, the change of material is always the same height off your foundation.
Wall finishes and grade |
Tue, Aug 31, 2010 at 12:33:10 AM
Sloped Grade Beam in Foundation Plan |
Thu, Jan 6, 2011 at 8:40:32 PM
Stone Water Table |
Wed, Nov 28, 2007 at 2:26:22 PM
How to model residential garage slab on grade with slope and stem walls |
Thu, Oct 10, 2013 at 3:30:52 PM
Building & site intersection lines |
Thu, Feb 3, 2011 at 3:18:52 PM
