28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Add 2 to Parameter Formula
Hello there, I have a parameter of integers to specify how many of an object there are arrayed. I would like to have this always add 2 to whatever the user inputs...how do I put that in the formula? Thanks, Lorne
Denver, CO
Revit Architecture |
You'll have to create an additional parameter. For example, the original parameter is "A". Create a new parameter "B". The formula for parameter "B" is A + 2.
I tried editing my original post with no luck. Set your array to parameter "B" and make sure the user edits "A". I think that's what you're getting after.
YEA THAT'S WHAT I ENDED UP DOING. I DIDN'T KNOW IF THERE WAS A WAY TO KEEP IT DOWN TO ONE PARAMETER. THANKS THOUGH.
Denver, CO
Referencing a Shared Parameter in a Family parameter formula. |
Thu, Jan 29, 2015 at 1:26:24 PM
Add size_lookup formula via Revit API |
Mon, Mar 21, 2016 at 8:53:25 AM
One family parameter has formula one has none |
Wed, Jun 25, 2014 at 1:05:54 PM
Including different formula parameter for each type? |
Wed, Sep 5, 2012 at 1:18:28 PM
Parameter Formula |
Fri, Mar 5, 2010 at 12:09:09 PM
