Forums >> Revit Building >> Technical Support >> section view
Thu, Nov 8, 2007 at 12:28:15 PM | section view
hkleoiki
in my building sections the walls are coming up soild gray. stem wall and footing is solid gray as well. there is no hatch pattern for cmu and footing. its is hard to see my detail components through the gray background in sections. any thing that i can do to get the visibility right. elevations work fine but not the sections. i attached an example
Thu, Nov 8, 2007 at 1:31:56 PM | section view
4 Stars: 205 Votes
You can't see the details because you are in "corse" mode, in left botton, just in the right units click and choose "fine".
Thu, Nov 8, 2007 at 1:51:59 PM | section view
hkleoiki
Thanks typhoon, tried it but it still shows up the same there was actually no change. i fiddled with those settings but still cant get it right. any other suggestions?
Thu, Nov 8, 2007 at 2:06:23 PM | section view
OktoberFire
OktoberFire Avatar
change the fill style for the walls in the wall properties?
Thu, Nov 8, 2007 at 2:48:53 PM | section view
hkleoiki
tried that too with no avail.
Thu, Nov 8, 2007 at 4:06:27 PM | section view
OktoberFire
OktoberFire Avatar
what scale are you viewing the section at?
Thu, Nov 8, 2007 at 6:08:57 PM | section view
TomDorner
4.5 Stars: 25 Votes
Have you checked your view settings for phase and phase filter?  Items created earlier than the current phase by default show up grey.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Section box in Section??
Sat, Dec 10, 2011 at 10:23:01 PM
13
Section line disappears from plan when section view is placed on same sheet
Thu, Sep 4, 2014 at 7:46:20 AM
Section Title View deleted can not recover
Tue, Jun 9, 2015 at 7:48:40 AM
Section view depth
Tue, Jul 15, 2014 at 8:29:07 AM
Section markers disappear in plan when cropping the section view.
Tue, Nov 27, 2007 at 3:33:58 PM
Page generation time: 0.6654
