Forums >> Revit Building >> Technical Support >> Walkthrough with Looking Up & Down
Wed, Nov 7, 2007 at 6:11:22 PM | Walkthrough with Looking Up & Down
RobM
Morning All,
I am struggling to find a way to get my camera in a walkthrough to look up & down during its wander through my model. Does anyone have any thoughts - greatly appreciated
Revt Building 2008 is being used.
Wed, Nov 7, 2007 at 8:39:09 PM | Walkthrough with Looking Up & Down
LIZARD2806
3.5 Stars: 7 Votes
Draw the walkthrough as you want it to be.
Go to a section view (or elevation view).
Right click on the walkthrough in the project browser.
Selct show camera.
On the Options bar, click EDIT WALKTHROUGH.
If not already, type 1 into the key frame (so you starrt at frame 1) and hit enter.
Then use the next key frame button to go to the key frame you want to change.
The current keyframe turns from a dot to a camera.
You can click, hold and drag both the camera (if you wanted for instance to walk up stairs) and the target (to look up and down).  Revit will automaticall adjust the target between the target of the key frame you adjust and the one before and after, so its smooth.  You may need to create a few exra sections to get what you want, but it is pretty easy.
Good luck.Cheers.
**Using Revit Architecture 2009, 2011, and 2012**
Thu, Nov 8, 2007 at 10:20:17 AM | Walkthrough with Looking Up & Down
NKramer
4 Stars: 9 Votes
You may want to look at this thread on the Augi boards.
http://forums.augi.com/showthread.php?p=778159#post778159
walkthrough
Wed, Aug 1, 2012 at 5:43:43 PM
Exporting Walkthrough Trouble
Thu, Apr 17, 2008 at 8:00:50 AM
walkthrough questions
Sun, May 10, 2009 at 7:49:41 PM
New to revit and have a question... Re: walkthrough on 2011
Tue, Apr 12, 2011 at 6:01:12 PM
Walkthrough
Thu, Sep 24, 2009 at 8:24:31 AM
Page generation time: 0.8166
