Forums >> Revit Building >> Technical Support >> View "Breaks"
Wed, Nov 7, 2007 at 2:39:14 PM | View "Breaks"
revitribbit
4 Stars: 1 Votes
Revit -2008
We have very tall wall sections that won't fit on our sheets...When I use the "break" view tool, it crops out the central portion of the wall, which is what we want ; however, how can we then move these two cropped regions closer together so they will fit on the sheet on top of each other (with break lines in between).  We know we can duplicate the view as a dependent and crop as necessary to review this - but were trying to utitlize the breaks that Revit gives us.
Wed, Nov 7, 2007 at 2:42:31 PM | View "Breaks"
revitribbit
4 Stars: 1 Votes
Nevermind... I solved my own problem...for those as "blind" as me, there is a little yellow in the center of each crop region that allows you to move that region, without affecting the others...
Tue, Aug 3, 2010 at 6:51:56 PM | View "Breaks"
camncam
I'm so glad you put in the solution when you found it, I was as blind as you were!
Tue, Oct 5, 2010 at 11:32:12 AM | View "Breaks"
marcpinard
Thanks, this was just the help I needed....couldn't find it in Autodesk help!
Tue, Oct 4, 2011 at 12:11:40 PM | View "Breaks"
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
Consider our entire office blind! We couldn't figure out how to do it either until we found this post. Thanks!
Tue, Oct 4, 2011 at 1:06:15 PM | View "Breaks"
As with describing anything, you have to use the right terminology.  ... and how would you know what this is calle?  It is the crop region and it is explained in the help: Resizing Crop Regions Graphically
Edited on: Tue, Oct 4, 2011 at 1:06:32 PM
Tue, Mar 5, 2013 at 10:17:52 PM | View "Breaks"
spacey
Thaks again! Searching under "view break", which seemed completely logical,  didn't find anything in help, and again, other users provided the answer when I found this post.
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
Plan Render-No "View Size"?
Tue, Jan 13, 2009 at 4:25:21 PM
{3D} view set to "Shading with Edges" looks like "Wireframe" with color...
Wed, Aug 12, 2009 at 7:05:45 AM
11
copy view crops and view breaks between views?
Tue, Apr 28, 2009 at 7:07:01 AM
How do I get out of "rewind" mode in 3-D view once I have clicked on it?
Tue, Mar 31, 2009 at 12:30:12 PM
Page generation time: 0.8937
