29 Users Online (27 Members):
Forums >> Revit Systems >> Technical Support >> I made a 2 toilet stall family...problems with insertion
I started a plumbing fixture family with a wall host default file. The wall thickness is 6". When I insert the component into a model with an 8" Nom. CMU wall, the component is inserted 1" into the wall. I understand that the 6" wall in the family is the reason, but is there a way to insert the component without changing the wall size in the family to fit the wall size of the model?
5 Posts No Rating |
If you base the massing off of the wall faces reference plane as opposed to the wall centerline, then the component will base itself on the wall face in the model, regardless of wall thickness.
Tagging a family within a family |
Mon, Oct 8, 2007 at 3:24:35 PM
Scheduling Components within Families |
Mon, Dec 1, 2008 at 11:57:25 AM
Interior Elevation Adjustments - things just aren't showing up!?! |
Wed, Jan 7, 2009 at 9:18:12 AM
masking region in toilet family - help me i'm a newbie! |
Fri, Aug 10, 2007 at 2:50:02 PM
Revit 2012 - Edit Room Boundaries |
Tue, Jul 5, 2016 at 9:38:18 AM
