22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Structural Visibility Issues
18 Posts No Rating |
Ok, I have my detail level set to "Medium" in my drawings, and I can see all of my structural objects; columns, beam, truss joist, etc. However, when I set the detail level to "Coarse", it all disappears. What am I doing wrong? Is this another setting by Revit that can't be changed? What can I do to see structure in a "course" setting? Also while your at it, can you tell me how to set component fill patterns to react to detail level changes like walls? In the property box for walls you can specify what fill pattern to use when you set the level to "coarse". I use "solid fill", and on "medium" and "fine" I want to see the actual "fill (hatch) patterns" I set in the "Object Properties" box when I created it. On components, you have to use the same "fill pattern" for all detail levels. Is there a way around this? Or am I going to have to change their fill patterns manually when I switch my project to a "medium" detail level? Thanks alot for your help!!
Post edited on 2005-02-18 10:43:06
Punched hole in shear wall visibility issues |
Tue, Dec 26, 2006 at 4:19:43 PM
linked file visibility |
Fri, Aug 23, 2013 at 8:05:11 AM
Structural framing not visible in plan |
Tue, May 20, 2008 at 4:56:35 AM
structural wall VS structural columns |
Tue, Apr 26, 2016 at 3:49:39 PM
Structural Framing in Visibility Graphics |
Wed, Feb 10, 2016 at 9:51:18 AM
