Forums >> Revit Building >> Technical Support >> Keynotes Help - edit the name but still have reference
Tue, Nov 6, 2007 at 3:31:37 PM | Keynotes Help - edit the name but still have reference
OktoberFire
OktoberFire Avatar
i was looking at this http://www.dgcad.com/Revit9-KeyNotes.asp
and i had ago myself at editing the keynote for drawings, i can edit the materials part but when i label parts it still has say F10    102mm Brickwork for a wall.
in the wall properties it has keynote as F10.
my question is, how can i add keynotes or make it so it only says 102mm Brickwork, ie there is no reference.
Wed, Nov 7, 2007 at 2:47:03 PM | Keynotes Help - edit the name but still have reference
OktoberFire
OktoberFire Avatar
i worked this out today and will post here for further information.
you can edit your Kenotes file, it is found here C:\Documents and Settings\All Users\Application Data\Autodesk\RAC 2008\Metric Library or Imperial the file is called RevitKeynotes_GBR.txt or may differ for USA Cryingnon metric) is the .txt file in the Metric folder.
within this file you can edit materials to what you like
F10/110 Clay facing brickwork F10you change the above to F10/110 102mm Facing Brickwork F10note you must keep the F10/110 and F10 between the label/text/description
once you have set up all your materials, you need to make some changes to the keynote settings.
the first image shows the default keynote on a wall within Revit 2008 Architecture
as you will see you have the ref code and the description, this ref code is important to remember.
you can turn this ref code off by doing the following - see the 2nd imageclick edit properties button Cryingnext to where it has Keynote Tag) then edit/new and untick Vis - Keynote Value then click Ok
you will notice that the ref code has gone but left a big gap to the description text, to edit this you will need to do the following
click on a keynote within the drawing and then click the edit family button and click Yes to open now all you do is drag the description text to where the ref code text and vice versa
see pictures 3 and 4
click load into project and your keynote should now be like pic 5
hope this will be of some help
29586_keynote01.jpg29586_keynote02.jpg29586_keynote03.jpg29586_keynote04.jpg29586_keynote05.jpg
Wed, Nov 7, 2007 at 2:48:06 PM | Keynotes Help - edit the name but still have reference
OktoberFire
OktoberFire Avatar
it hasnt came out very well in the post, i will work on a html page for better reading
Thu, Nov 8, 2007 at 2:19:43 PM | Keynotes Help - edit the name but still have reference
OktoberFire
OktoberFire Avatar
a quick html file of the above post.
Thu, Nov 8, 2007 at 2:19:55 PM | Keynotes Help - edit the name but still have reference
OktoberFire
OktoberFire Avatar
forgot the link!
http://lofguild.co.uk/keynotes/keynotes.html
Keynotes
Thu, Mar 15, 2018 at 3:15:03 PM
Keynotes
Thu, Oct 6, 2005 at 5:13:33 PM
Constraining Reference Planes to Roof Pitches
Mon, Feb 5, 2007 at 6:53:14 PM
KEYNOTES: only one keynote txt file and legend?
Wed, Jan 17, 2018 at 12:33:01 PM
Detail reference tags
Tue, Feb 7, 2017 at 11:22:08 AM
Page generation time: 2.4517
