9 Users Online (7 Members):
Forums >> Revit Structure >> Technical Support >> Footing steps in Revit Structure 2008
1 Posts No Rating |
How do you do footing steps in structure 2008? I can not quite figure it out. -Thanks
46 Posts No Rating |
We just do short segments of walls / footings and then just adjust the bottom of the wall accordingly. Dont know if there is a better way or not, but it is the only way we could figure to have them display correctly in the 3d view. The step itself is a really thick but short footing.
2 Posts No Rating |
there is a tutorial in revit structure 2008, if you don't have it you can download it from autocad. it gives you step by step instructions and it works i have tried it myselfand so you don't have to look for it it starts on page 404. you have to have all the tutorials download for it to work though so make sure you download all the tutorials they are a big help in figuring out how to do a lot of things in revit.
Footing steps in plan |
Wed, Feb 3, 2016 at 2:10:50 PM
Wall Footing on Walls w/ Modified Base Extension |
Thu, Nov 21, 2013 at 12:06:48 PM
Stepped Footing |
Sun, Nov 7, 2010 at 7:35:38 AM
Structure Suite 2008 |
Tue, Apr 17, 2007 at 3:19:52 PM
Wall Footing for copy monitored element. |
Tue, Jan 22, 2008 at 4:25:40 PM
