Forums >> Revit Structure >> Tips & Tricks >> sloped joist framing/RAM
Tue, Nov 6, 2007 at 8:33:56 AM | sloped joist framing/RAM
JamieF
I'm going to try to abbreviate what I'm trying to accomplish so this doesn't turn into a 5 page thread - hopefully you can follow.
Roof framing plan, single slope front to back.  Joists spanning front to back bearing on joist girders (I've just used an LH joist as a joist girder).  I've created a roof at the slope I need and applied a reference plane to it's underside.  I can get the framing in no problem.  The problem is exporting to RAM.  If I leave everything as default for vertical offsets, etc. it will go into RAM without errors.  As soon as I try to adjust so the joists are actually sitting on top of the girders and the tops of the columns are down with the slope of the roof I start getting unsupported memeber errors in RAM.
What am I missing here?  Has anyone figured this out??
Thanks for any help/info you can pass along.
Sloped joist line type
Thu, Nov 25, 2010 at 12:25:02 PM
Joist Seats on sloped joists
Wed, Oct 24, 2012 at 1:27:46 PM
13
Sloped framing and framing plans
Tue, Apr 11, 2006 at 7:47:26 PM
Sloped Structural Joist
Mon, Nov 7, 2005 at 12:14:32 PM
Sloped joist seat
Wed, Oct 24, 2012 at 1:26:11 PM
Page generation time: 0.1079
