Forums >> Revit Building >> Technical Support >> Double section tags
Mon, Nov 5, 2007 at 4:41:22 PM | Double section tags
mebowles55
I have a two tags (1 wall section and 1 callout in a building section) that are linked to the same view. I don't want to have the callout linked to the view but I try to erase it and get the warning that it is going to delete the view. Then I tried to erase the wall section tag, assuming that it was just a reference view, but I got the same warning.
 Any ideas as to how two tags can be directly linked to the same view?
Mon, Nov 5, 2007 at 4:44:51 PM | Double section tags
Unless the one says similar, they are probably the same view.  Just hide in view the one you don't want.
Mon, Nov 5, 2007 at 4:49:38 PM | Double section tags
mebowles55
Thanks WWHub.
I found that the callout was created because the wall section tag was in the view range of the building section. So hiding the callout works.
section tags for broken wall sections
Fri, Dec 7, 2007 at 10:57:25 AM
Section Tags missing (again)
Wed, Aug 26, 2009 at 10:50:38 AM
Floating Section Tags
Mon, Nov 26, 2007 at 1:09:03 PM
room tags in section
Wed, Jan 10, 2007 at 11:22:58 AM
Elevation Tags not showing when I cut a Section View
Mon, Oct 20, 2014 at 2:43:05 PM
Page generation time: 2.5141
