Forums >> Revit Building >> Technical Support >> Exporting Text Notes, Detail Items, and Cut Pattern
Mon, Nov 5, 2007 at 1:20:52 PM | Exporting Text Notes, Detail Items, and Cut Pattern
superelboogie
Hi. Im exporting my files to dwg files. I have editted the Export Layers Settings for every stinkin object in the files. For some reason my text all comes in on the right layer but the color in overriden. WHY!?!?! How and where do you set an override for text. The text color is Black becuase it has to be to print from revit. But when you export it still wants to be overriden as black/white instead of "71" like the layer should be.
Also the Override for the cut pattern on the walls come in as a completely random "Color 55" override. Why does Autocad not acknowledge the color that I specified in the Revit File. And the othery problem is that the fills are all sorts of screwy and dont fill in the same area as it does in Revit.
ALSO... I have specified a detail items categories in the family and they should up correctly in Revit, BUT when I export the lines do not go to the correct layers that I specified in the Layer settings, they just are the generic Layer setting for all Detail Items. Whats the point on having all the subcategories set to certain layers if its not going to follow it.
LAMENESS! Im so having a stupid monday. Someone help me PLEASE!
Adding text notes to a detail
Mon, Dec 10, 2007 at 11:55:09 AM
Production Text Notes - Global Visibility
Wed, Mar 8, 2017 at 1:43:55 PM
Saving text notes
Wed, Feb 24, 2010 at 12:34:43 PM
Trouble copying detail items from Section View to Drafting View
Mon, Aug 19, 2013 at 1:08:05 PM
DETAIL GROUP: INCONSISTANCIES w-PLACEMENT of NOTES
Mon, Dec 8, 2008 at 8:37:37 AM
Page generation time: 2.4780
