11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> View Title Extension Lines
I was wondering if there was a way to modify/edit the extension lines of the view title families. Our office standard has an extra wide line with a thin line 1/16" above it. Is there a way to have two lines for the extension lines? Thanks,
cad.web.print website: http://www.thinkdesign-studios.com blog: http://www.bimtionary.blogspot.com/ |
You can not modify the automatic title with the adjustable line. Instead, you can make your own view title with fixed length lines. Might want one or two different sizes.
WWHub is mostly correct, although I do not know of a way to have a double line, you CAN modify the standard extension line, but only the line weight and line pattern. Select the viewport title, then go into preferences, then click Edit/New. There you have the option of changing the line weight and line pattern. I quickly looked to see if you could create a double line line pattern, but did not see anything.
**Using Revit Architecture 2009, 2011, and 2012** |
Hello... When the name of the view on the View sheets is a litter bit longer than usually, it takes two lines and the second one cut's the bottom’s line... How can i deal with it?... please!!
View Title Extension line |
Mon, Apr 23, 2007 at 6:38:22 PM
Deleting View Title Extension Line. |
Thu, Dec 27, 2007 at 10:06:05 AM
Automatic View Title Extension Length |
Sun, Dec 18, 2016 at 5:45:56 PM
View title extension line grips trouble |
Wed, Oct 9, 2013 at 2:04:27 PM
Is there a way to reverse the View Type Title? |
Mon, Aug 22, 2011 at 3:26:46 PM
