21 Users Online (19 Members):
Forums >> General Discussion >> Revit Project Management >> Unable to add window to wall
1 Posts No Rating |
I have a 90mm brick wall and I recieve an error when trying to add a "Tpl Casement Top Hung Window" Get the following errors: Can't make type "Tpl Casement - Top Hung Side". None of the created elements are visible in Floor Plan: 00_Ground Floor View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
I suspect your wall may be below the minimum thickness for that particular window family- you may have to make a copy of that window family and edit it to suit. Regards,Ian
www.RevitZone.com News / Articles / Tutorials / Forums / Beginners Guide to Revit |
3 Posts No Rating |
I would agree that is most likely the issue. Make sure that the window is not too large for the wall thickness. That is the typical error.
1 Posts No Rating |
Why do you need to be able to put a window in your wall? Oh, sorry - I was channelling AUGI moderators again...
Fleetwood window families unable to offset form exterior |
Tue, Oct 18, 2016 at 10:24:42 AM
Wall and Window problems please help |
Tue, Jul 8, 2008 at 10:21:30 AM
Adding Windows To Building: Help Needed Please |
Wed, Jun 10, 2009 at 3:14:31 PM
existing wall keeps infilling when I add a window. |
Sat, Nov 5, 2016 at 2:01:05 PM
how do you set a window back from the face of the wall of an exisitng window? |
Tue, Mar 13, 2012 at 10:36:59 AM
