Forums >> Revit Building >> Technical Support >> weird question
Fri, Nov 2, 2007 at 10:13:26 PM | weird question
Grace101
Hello, I am attempting to design a large motoryacht for my design class. I have designed the hull in a program called Delftship, and i exported it in a .dxf format. I want to design the interior around the hull in Revit, and i can upload the polymesh .dxf surface into Revit. However, I cannot use wall by face to create a "hull" on this surface. I am only a junior in high school and i don't know much about CAD formats.
 ANY information you can give me will be SO much appreciated.
Thank you,
 Will
Mon, Nov 5, 2007 at 1:48:17 AM | weird question
IDN101
2.5 Stars: 3 Votes
Hi,
Can you tell us more about what happens when you try to use Wall By Face? What messages do you get from Revit?
www.RevitZone.com
News / Articles / Tutorials / Forums / Beginners Guide to Revit
Mon, Nov 5, 2007 at 12:10:59 PM | weird question
Jackazstuntman
3 Stars: 2 Votes
USE MASSES. THEY HELP ALOT WITH WEIRD SHAPES, ALSO THEY ARE MORE FLEXIBLE...JUNIOR IN HIGH SCHOOL... WHICH ONE...SANTIAGO IM GUESSING.?
DKO
Mon, Nov 5, 2007 at 2:33:48 PM | weird question
Grace101
hi, thank you guys for your reply. santiago? i have no idea what youre talking about...
 anyway when i have the mesh in 3d format, the wall by face will work on a few of the individual faces on the mesh, but only a few. Its confusing, i am uploading the .dxf format so you can see it for yourself. By the way, I am using Revit Architecture 2008.
Weird tag problem, question mark?
Wed, May 9, 2012 at 6:52:38 AM
Weird Callout Problem
Wed, Mar 19, 2008 at 2:51:20 PM
11
problem pads and subregions , weird depression on topography
Sun, Mar 22, 2015 at 1:46:45 PM
Weird blocks of color appearing when plotting
Fri, Apr 19, 2013 at 3:19:00 PM
Revit 2017 weird mapping in shape-modified floors
Thu, May 11, 2017 at 11:56:49 PM
Page generation time: 0.2418
