Forums >> Revit Building >> Technical Support >> Revit Downloads
Thu, Feb 17, 2005 at 9:42:04 PM | Revit Downloads
MongooseST3
I am a new user to Revit. I have joined this site in an effort to obtain components specific to my work. When I download items from this site where do I put them in revit to obtain them. I have also noted ZIP files inside Revit. Are these supposed to be unzipped or are they placed there by the install program and unzipped when revit is installed??
Fri, Feb 18, 2005 at 12:03:34 AM | RE: Revit Downloads
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
if you put the downloaded families in your library they will be easy to find. The default location for your family library is C:\Documents and Settings\All Users\Application Data\Autodesk\Revit 7.0\Imperial Library (or Metric Library)
Hiroshi Jacobs
Fri, Feb 18, 2005 at 1:42:46 AM | RE: Revit Downloads
timOthyj
4.5 Stars: 14 Votes
I have also noted ZIP files inside Revit. Are these supposed to be unzipped or are they placed there by the install program and unzipped when revit is installed??You must unzip them (www.winzip.com)
And then store them where you know where they are and then when in revit go to to file/open/slect the file and the wa bam!!!
Revit opens it ..
It will probably do a upgrade, no worries this is typical.
Note:
Once you open a file in a later version of revit you cannot open that same file in a prior version.
Flooding of files in downloads
Tue, Sep 20, 2022 at 5:04:20 PM
downloads compatible with revit
Wed, Jun 4, 2008 at 12:50:40 PM
Finding Quality Downloads 4 Creating Quality Downloads
Thu, Feb 2, 2006 at 2:45:17 AM
Revit 2012 Student Downloads and Serials Available
Mon, Apr 25, 2011 at 10:23:34 PM
Downloads
Thu, Jun 14, 2018 at 8:04:41 AM
Page generation time: 2.2782
