Forums >> Revit Building >> Technical Support >> Changing the associated level
Fri, Nov 2, 2007 at 2:57:24 PM | Changing the associated level
jasonkinnard
One of my floor plan views is associated to an incorrect level that is 3' below what it should be. The building is located on the appropriate level. As such, wall hosted items are either not appearing, or are appearing incorrectly.
How can I change the associated level of this floor plan view?
I saw elsewhere on this forum that with a similar problem, someone suggested creating a new view with the correct associated level and then copy-pasting any details over. I have not found this to be helpful. I have callouts that are already fully detailed and when I copy paste them, all it does is essentially create a new callout with no notes, dimensions, etc. This suggestion seems to require me to redo every detailed callout on the sheet.
Sat, Nov 3, 2007 at 6:32:38 AM | Changing the associated level
IDN101
2.5 Stars: 3 Votes
Do you have many wall-hosted elements that are incorrectly placed? If not too many- why not just change the Elevation / Offset parameter for these elmements to compensate?
Regards,Ian
www.RevitZone.com
News / Articles / Tutorials / Forums / Beginners Guide to Revit
Mon, Nov 5, 2007 at 8:50:02 AM | Changing the associated level
jasonkinnard
To elaborate more...one of the major issues we are having with that building is that our MEP consulants are taking the model and trying to wall-host and insert objects into that floor plan view and they are not showing up, because of the wrong associated level.
It seems counterproductive to just change offset parameters for everything that is inserted and to have to tell our consultants to do the same.
My thought was, that if somehow the floor plan view can become associated with the wrong level, then it should be able to be modified back to be associated with the correct level.
I can't imagine how the view could have bceome disassociated with the proper level in the first place.
Mon, Nov 5, 2007 at 10:11:39 AM | Changing the associated level
jasonkinnard
Changing model constraints from one level to another
Wed, Aug 12, 2015 at 3:29:36 PM
Changing Level Heights
Mon, Jun 18, 2012 at 10:55:28 AM
Changing Level 1 to match site information
Mon, Jun 7, 2010 at 7:14:16 AM
Changing the detail level settings
Mon, Jul 27, 2015 at 11:27:45 AM
Changing View Range to a lower level?
Tue, Feb 17, 2009 at 7:25:00 AM
Page generation time: 1.4315
