15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Window Swings Not Showing In Elevation
I have a building with a slanted wall and the window swings are not showing in elevation. I know that this is supposed to happen since the wall is technically not in true projection, but how can i override this? I have tried changing the lines in the family from symbolic to model and they still do not show. Can anyone help?Thanks,Jimmy
You model lines in the window family will need to be on a plane that is in front of your window. If you have some experience, you could make these a switchable item that is turned off in your 3d - otherwise the model lines will show up there too.
Window elements not showing in one elevation. |
Mon, Jun 12, 2023 at 7:15:06 PM
Door swings not showing in plan view |
Mon, May 5, 2008 at 7:27:38 PM
Door and Window Frames not showing in Elevation |
Thu, Dec 17, 2015 at 4:34:06 AM
Exterior wall brick showing in window |
Tue, Sep 7, 2010 at 12:59:13 PM
Phasing Issue - Proposed Elements showing solid white |
Thu, Sep 3, 2015 at 7:36:04 AM
