Forums >> Community >> The Studio >> import lineweights into new family
Thu, Feb 17, 2005 at 9:03:52 PM | import lineweights into new family
aabrmn
Is there any way to do it? I builded a fireplace starting from a forniture/bed family template. when I go and start drawing symbolic lines I only get one lineweight in the selector. Should I start from scratch using another template with more lineweights? Can you import objects from family to family? How do you edit constraints associated to dimensions of objects (height, width extrusion lenght, etc...)? Thank you. Post edited on 2005-02-17 21:04:51 Post edited on 2005-02-17 21:05:13 Post edited on 2005-02-17 21:05:34 Post edited on 2005-02-17 21:05:52
Fri, Feb 18, 2005 at 9:53:54 AM | RE: import lineweights into new family
aabrmn
ok, ignore the first issue, I figured you need to create a new subcategory.
import lineweights
Wed, Apr 30, 2008 at 9:21:35 AM
imported dwg lineweights, linetypes
Fri, Aug 10, 2007 at 9:22:53 AM
Import line weights from DWG?
Wed, May 9, 2007 at 11:27:58 AM
Lineweights Question
Wed, Aug 3, 2005 at 4:03:11 PM
Looking For Easy Way to Control Lineweights When Linking DWG Files
Fri, Jan 18, 2008 at 3:17:58 PM
Page generation time: 2.6759
