10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Wall sweep not cutting right with a door
16 Posts No Rating |
Hi, I have tile in a restroom going all the way up to the ceiling and when it gets to the door it is cut above the door. Is there a way I can fix this? Please see attached. I'm using Revit 2008. Thanks! Surfrusty
This is not an answer to your question, but I was in the same situation, and what I did was to create a wall type of just the tile (new tile being applied to an existing wall), and then joined the two walls together. By joining them, both will be cut by the door. Hope that helps.Cheers.
**Using Revit Architecture 2009, 2011, and 2012** |
Thanks! That worked!
Door not cutting joined wall |
Wed, Feb 14, 2018 at 12:54:54 PM
door opening cutting parallel wall |
Mon, Sep 15, 2008 at 2:54:10 PM
gap in wall sweep without wall opening? |
Thu, Apr 22, 2010 at 3:14:20 PM
how to make door frames cut wall sweep? [ 1 2 ] |
Mon, Jun 9, 2008 at 8:11:27 AM
20
door not cutting wall |
Mon, Apr 6, 2015 at 10:24:32 AM
