9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Sq. Ft. of a Mass
2 Posts No Rating |
Trying to calculate the square footage of a Mass.The surface area seen in plan.The mass tag label calulates all mass surfaces.So, I tried applying a floor area surface to the mass to calculatesquare footage. It works and I can use this information for scheduling.The problem I run into is when the mass is irregular shape.Solid void applied. See attached image.I cannot get an accurate square footage because the Floor Area Face will notadjust any closer then 2". If I move Floor Area Face Level less then 2" the plane cut for the floor face disappears. Any thoughts on this would be appreciated.Eric
Cutting a section through a mass |
Sat, May 16, 2020 at 4:21:54 AM
Help wth Mass Please ! |
Wed, Nov 25, 2009 at 2:53:24 PM
Mass not showing completely |
Thu, Oct 30, 2008 at 11:51:16 AM
12
printing mass elements |
Wed, Dec 10, 2014 at 2:46:06 AM
Lighting and Mass |
Sun, Mar 18, 2012 at 11:03:57 AM
